Jims RV-8
Date:  11-8-2020
Number of Hours:  1.50
Brief Description:  Panel Plan #17
I wanted to add in some more of the dimensions for the right-side panel. The points were on the 1/4" grid lines for the most part - but better to just call out the measurement instead of making Bob do the counting and calcing. He's doing enough work on this already and I really appreciate him cutting the panel in his milling machine.
I didn't take a picture of the revised right-side panel - but fear not, you will get another update...
I also wanted to look at how bright my proposed low voltage lights would be when activated. These are the B and C provided lights so they should be good, but I wanted to make sure that I would be able to see the light if it activated in the daylight. I hooked it up to my 12V aux power supply and experienced a bright light. This will get my attention in day or night lighting. Bob has two spare B and C lights, so with my two yellows indicating low voltage on either alternator, and a red and green from Bob, I will have my starter on (red) and smoke on (green) annunciator lights covered.
I also double checked my electrical schematic and worked up a circuit breaker order from BandC.com as they have the best pricing on CB's that I have found.
Bright light - good to go
