Jims RV-8
Date:  2-15-2020
Number of Hours:  3.50
Brief Description:  Rear baggage lighting
Bob and I continued working on the rear baggage lighting. These lights are not controlled by a dimmer so they are full on and very bright. I also decided to keep it simple, lighter and cheap and just put the front and rear baggage lights on the same 1-3 switch, so there will be OFF and BOTH ON. We ran the wires, and all that entails, connections, labels, etc. and installed the lighting going up and over the span of the baggage area in a half moon configuration from left to right. I had originally planned on making it a “house shaped” configuration from front to back, but Bob suggested to just run it from right to left span-wise and I ended up liking that idea better.
wiring before tie downs
bright lights!
bright lights!
