So in thinking about the electrical needs, I need to loop back around and finish the installation of the landing / taxi lights. The lights needed a a little more sanding and then I installed the screws and tested the fit against the specs - looks good on the left and the right.
I didn’t want to glue the tips in until I had the molex connector installed as the wires off of the lights are not very long. In theory, the light is likely removable and re-installable, but the pivot point that gets glued or riveted into the wingtip doesn’t look very forgiving and I don’t want to be over-using that functionality – so I will wait until the molex connectors are crimped onto the wires.
