Brief Description: A Micro Mesh cleanup of the canopy spots
I had a few areas on the inside of the canopy where the sika primer bled under the tape and caused some black etching. Using the Micro Mesh method I was able to clean up the areas. It takes time - but the results are outstanding. Thanks for the tip on Micro Mesh, Bob!
I tried to take the same pictures on the before and after shots below to show the reconditioning - the lighting is a little different, but you get the idea.
