More heating and caressing of the canopy skirt. I was able to massage the bottom left side of the skirt to a mostly straight form. The aft curve that was showing a gap was worked too and the gap is better. I can likely live with the current look on the left side. Went to work on the right side and it is not currently at the same satisfactory level as the left side. For the side gaps I was able to heat the canopy skirt while pushing the side gaps in and cycle from heat to cold air to reform the skirt to a better shape.
Getting really close to bonding the left and right sides of the canopy skirt.
