I bent the ramp for the curve that goes up into the hot side of the firewall and then before making the side bends, I realized when I double checked the measurement, that I was a little wide...glad I double checked if the ramp would fit - otherwise the small amount of "extra" would have caused an unusable part once I bent the sides. As it is, I was able to re-drill the cut line hole stress reliever, which will move the bend line in and then I will re-cut the firewall curve. The gap caused by moving the hole inward is a non issue as that will end up being the bottom of the side-tab and is cut away.
