Brief Description: Final Fuse Assembly – Prime F-824’s
I riveted the Baggage ribs to the web of the 807 Bulkhead and then prepped and primed the F-824 Aft Side Skins. I didn’t use the Stewart Systems Ecoprime, but rather, the Rustoleum self etching primer that my buddy Roger pointed me to. First, I cleaned the scuffed skins real well with MEK and then I primed the rivet lines only – since these are aft of the rear baggage compartment and won’t be in a harsh environment. Many builders do not even prime these parts at all. It can now dry overnight and tomorrow I will backrivet the aft mid longerons to the side skins
