Part of tonight’s work session could be filed under "Shop" as I received my shop air conditioner back from the service center - but that's another issue for another day... After I mounted the a/c system and routed the condensation drain line I moved onto the left elevator.
I bent the left elevator tabs on the trim tab side and then bent the trailing end so that the elevator would lay flat. Good to be back for a few days after Sun n Fun...but SnF was a blast!
