Brief Description: right elevator work...substructure/skin
Did a lot of little things tonight... built the right elevator substructure,,,attached skin and final drilled the skin to substructure...dimpled the small skin that covers the counterweight and countersunk the counter weight to accept the dimple and the screw. Even though I haven't rivetted the stiffeners to the elevator as I am trying something different - I went ahead and bent the elevator so as to get a true fit on the skin. I might need to un-bend the skin to be able to reach the trailing edge rivets but we will see....
