Ivans RV 10
RV10
Aileron Actuation
5-24-2008
Torque Tube to BellCrank Pushrod
23-2
Step 1: Made two Torque Tube to Bellcrank Pushrods from AT6-049 x 1 1/4 tube.
Step 2: Built my own jig for locating rivet holes in Torque tube. (See Pictures)
Step 3: Match drilled the VA 169 Threaded rod ends into each of the torque tubes.
Removed parts and deburred then primed all pieces inside and out.
23-3
Step 1: Made two W-1018A Bellcrank to Aileron Pushrods from ST4130-035 x 1/2 Steel Tube.
Step 2: Drilled 4 #40 pilot holes in each end of both pushrods.
Deburred inside and out.
Step 3: Match drilled the AN490-HT8P threaded rod ends into the pushrods.
Step 4:Marked all parts for proper orientation then removed and primed inside and out where paint was removed.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
