Step 4: Clamped Mid Fuse Longeron on top of Tailcone Longeron. Checked alignment then clamped into position. Match Drilled the four holes on each of the Mid fuse Longerons into the Tailcone Longerons. Placed AN3-5A bolts nuts and washers onto longerons.
32-3
Step 1: Made .032 Shims to place between Longerons and Tail cone forward top skin and mid fuse longerons.
Step 2: Clecoed the F 1074 Forward top skin to the tailcone.
