Ivans RV 10
RV10
Prep for Tailcone Attachment
Step 1: Final drilled #30 holes common to the F1006B,C & A bulkheads.
Step 2: Final drilled #40 the 3/32 holes along top edge of F1006B Bulkhead and nutplate holes.
Step 3: This step completed as part of newer kit.
Step 4: Removed and deburred all parts from previous steps.
Step 5: Dimple nutplate attachment holes in flange along top of F 1006B
Step 6: Dimpled #40 holes along top edge of F1006B.
Step 7: Dimpled 3 holes in each of F1006A & C to match dimples in F1006B.
Step 8: Dimpled #30 holes in F1006B and corresponding holes in F1029 Bellcrank Ribs.
32-2
Step 1: Removed F1006B from tailcone and attached to Baggage ribs.
Step 2: Clecoed tailcone skins to the mid fuselage skins. Mid Fuse skins are on outside.
Step 3: Final drilled the#30 holes common to the aft flange of F1019,1020 & 1021 Baggage Ribs and the F1006B bulkhead.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
