Brief Description: Bulkhead Channel, Bell Crank Rib and Rib Angles
Clecoed Baggage Bulkhead Channel to Bell Crank Rb and 1006 Bulkhead, then final drilled top holes commom to Bulkhead Separated the Bell crank Rib Angles and final drilled nut plate holes 3/32 or 1/4 depending on location Now (2) 1037A, 1037B, 1037C Clecoed 1037B & C Bellcrank angle to L & R Bellcrank RibsFinal Drilled all the holescommon to Bellcrank Angles, Bellcrank Ribs and Bulkhead Channel Made 1010B Spacer out of AS3-125x1.00 AL. Marked dimensions as stated in Step 3, 10-10 Put Longerons into place and checked for proper fit
