Brief Description: Drilling Longerons, Frames and Bulkheads
Clamped Longerons into place to Side Skins and Aft Deck as per A-A page 10-11 Match drilled holes common to 1073 Side Skins and Longerons Final drilled all the rest of the Skin to Frame and Skin to Bulkhead holes except for any holes in 1006 Bulkhead Final drilled 3/32 holes common to 1012A & B BulkheadWebsand the 3 holes on top of Bulkhead Webs common to 1014 Aft Deck Final Drilled the Skin to Frame and Skin to Bulkhead(except 1006 Bulkhead) holeson Tailcone Bottom Final drilled holes common along edges of 1073 Skinsand the 1078 and 1079 Bottom Skins Removed narrow strip from 1074 Forward Top Skinand finished edges of both parts Finished edges of all parts used this entry
