Bent the lip to 90 degrees. Cut the V notch of approximately 25 degrees. Put the horn in a vice with wood for protection and tapped the horn to an angle of 65 degress per the plans. Cleaned all the layout fluid off then coated with WD40 to keep the rust at bay while I work for a week.
