Brief Description: Rib trimming U Jig prep -13 rib setup
Trimmed the tails on the lower wing short ribs. Added filler pieces to full ribs at the tail. Sanded and taped the U3 jig. Cut and sanded all pieces for the 4 -13 ribs except the nose shims. Glued the double noses together. Inventoried the 1/4x5/8 capstrip. There are enough pieces to finish all upper wing ribs easily.
