Marked and cut out the pass-thru holes for the aileron control tubes in the walkway rails. Used the belt sander and a round file. Roughed up the plywood rib glueing surfaces then glued, stapled and clamped all four rails. Made a template to mark and shape the short rails that go behind the rear spar and to the trailing edges.
