Greg's Model 12 Build
Model 12
Bellcrank and idler work
Finished cutting the bearing cage outer and inner spacers. Laid out the -17 bellcrank arms, cut the 1" holes, 3/16" holes and rough cut them from the sheet. Also cut one -18 arm to use up the remaining linear space on the bottom of the .050 sheet.
Bearing cage spacer
-17 bellcrank arms laid out
Model 12 Home
641
Flight Controls
472
