Trimmed and drilled the F-757 Gussets to fit the longerons. Clamped the F-714 Aft deck to the rear after making sure the fuselage was level with no twist in the rear, drilled this through the longerons. Deburred the holes in the longeron, match drilled the two spacers which go underneath the aft deck, deburred the holes.
