Drilled holes in the F-695 gussetts and then match drilled them to the longeron and horizontal angle on the firewall, prepped and primed parts. I also drilled, prepped and primed the 2 seat belt anchor harnesses. While I had primer in the gun I also lightly scotchbrited the area where the rudder stops go on the rear of the fuselage, riveted these on. Clecoed and then riveted on the aft deck, even had to get the horizontal empenage and sit it on the back and have a look along with the vertical. Riveted on the F-709 bulkhead. Riveted the F-757 gussetts to the fuselage and the F-695 gussetts also.
