I had some spacer bars made up in the thickness of the wing spars for when I was assembling the main spar bulkhead, so I thought I would put these to good use again by welding some steel plate to them and then bolting them to two thik posts to act as the fet for the fuselage. Made them a nice distance off the ground so I can work on the inside. Then I went back and bolted and torqued the bolts going through the main spar to the seat ribs, I deliberately left these out so I could get a bucking bar on the floor rivets. Bolted the rudder pedals in place, although I may need to take these out again when painting the inside. Kids decided to have a sit inside, now Alex want's me to really hurry so he can go flying.
