Nearly finished the wiring. I extended the wires for the fuel and oil pressure sender units, wired up the MAP sensor, mounted another earth point on the inside as I had run out of earth tabs on these. I have run every earth/ground point back to a common ground, so if I have a fault somewhere I can at least check this first. Wired the remaining wires into the Dynon Skyview harness, soldered on the supplied 30kOhmn resistors to small cable with one end connecting to the P magneto lead and the other to the Dynon. When I put in the auto pilot cable loom in, I somehow had the pitch and roll wires around the wrong way, so instead of having to swap them over, I had another plug for the rear of the auto pilot and cut and soldered the leads and swapped over (a pain). Bolted on and safety wired the spinner plate as well.
