One task needing done was to be able to lock the canopy. Using a cam lock from a local hardware store this is used for draws/cupboards, I drilled a hole in the side of the canopy fairing, drilled and filed two slots on the top of the railing. Works great to lock the canopy when fully closed and I made another slot where the canopy can be locked with a slight opening so on hot days it can be in this position. Tidy up the slots and touchup paint required.
