Made a mount for the fuel transducer which bolts onto the firewall out of spare aluminium angle. Fitted my new start switch (the old one was on/off) which is off and momentary on. Connected and ran the two shielded mag wires, connected only the shielded wire end to the mag, the other end of the shield is not connected to ground. At the switch the P-led circuit is opened when the switch is ON and closed when the switch is OFF. Took a while for me to get this, as normally when a switch is ON a circuit is closed. The Dynon Skyview has a cable with a USB port so as screen shots, downloads etc can be recorded. So with this in mind I didn't want to be digging for a cable, so fitted a panel mount USB which takes the fitting from the dynan and has the USB port in front, looks neat.
