Brief Description: Panel cut and antenna doubler plate
All the holes are nearly cut out on the panel. I just need the Garmn SL40 radio rack so I can cut that hole and then start adding bracing on the racks. I did the antenna doubler plate and drilled the holes in the top skin. I decided to go with platenuts under the doubler plate so it will be easier to take the antenna on and off if need be and it should also make a good earth contact from the screws through the platenuts.
