After much deliberating, measuring, measuring and re-measuring my holes and cutouts, I started to plan my panel. Because I'm now going for the Skyview 10" I had to rearrange where everything is going to go. I wanted everything uniform, inline and pleasing to the eye, seeing as how this is where the pilot looks (apart from outside). So the only steam gauge I'm having is the airspeed indicator on the left side of the screen with my trim indicators for flaps and elevator to the left and below the gauge. A start switch on it's own with the rest of the Aveo rocker switches mounted along the bottom. A trio pro pilot will go to the right of the screen with a panel mount compass above it (I didn't want one up on the windscreen). Then an Avmap GPS with panel docking with the Garmin SL40 and GTX327 transponder underneath the GPS. I love the setup. Now that it is planned I started to cut the holes out.
