Now that I'm doing another panel, I wanted to be able to remove the panel if need be. The problem was on the original panel I had a park brake coming through the panel on one side and a heat vent push/pull on the other, also the air vents were part of the panel edge as well. So I decided to build new larger vent panel parts that can be removed so I could remove the panel if need be without the hassle of all the push/pull/park brake levers, also now I can run my park brake above the vent on one side and the heat cable on the passenger side,without coming through the panel, looks great as well and free's up more actual panel space. I added the curved side to add strength and looks fuller. It took 2 prototypes to get it right.
