Riveted on the doubler plate for the antenna, crimped on the BNC connector and ran the cable down the side and held in place with cable ties which have a mounting hole attachment, ran it through the already installed conduit, down the centre and up the side in between the spar. I thought I would run the coaxial cable as far from any other cables as I could to reduce interference.
