Brian's RV-7 Web Site
Date:  10-9-2010
Number of Hours:  5.00
Brief Description:  Engine start
added antiscuff tape to the flaps and hooked them up.
timed the Emag/Pmag's. Gapped and installed the spark plugs.
Pushed her outside and after hand propping a bit, I tried to use the starter to prelube the oil system. No go, found a bad crimp on the starter solenoid. fixed that.
did the first engine start....WOOHOO! she runs great, once you flip on the mags.
engine start video: http://www.youtube.com/watch?v=x6BzqHS40dw
2 engine run video: http://www.youtube.com/watch?v=KoVXFEoZyiE
let things cool and then ran it again to check more engine parameters. Got couple of things to look into. (I was showing 30amps ALT output, also 7gph at 1200rpm)
GREAT DAY
