Received my Bower Aviation RamAir filter system today. Initial attempt at mounting, showed it does not fit. DANG IT! After a call to Rod bower, he asked me to check a few things. Turns out I need a different starter that has the solenoid on the opposite side. quick Call to StenDec and spoke with John, since he built my engine. He said "no problem, send it back I'll send you the correct one" Great I'lll only be out a little postage, which is better than I thought.
