In the morning, I added bracing to the left side rear baffle. trimmed both left side pieces.
After work I went back and started right rear baffle fitting. I got the heat supply flange w/screen riveted in place , then cut the plug wire holes and fitted the grommet for it and the purge return line. Next was trimming the right side baffles. Done
