Brian's RV-7 Web Site
Date:  4-19-2010
Number of Hours:  1.00
Brief Description:  remote oil door and cowl split
added tube and cable for remote oil door actuator. It's a simple AL tube with a hinge pin inserted. one end is under the glaresheild other end gets routed into a tube on the upper cowl. Need to finish the oil door next.
Also added tubing for cowl split hingepins also. They will end below the subpanel .no pic
