Pulled the left wingtip and finished wiring the lights.
Tested the landing lights..A-ok Tested the strobes....A-ok Tested the Nav lights ...A-ok
Tightened jam nuts on the control stick, found 1 nut missing (fixed) on elevator rod end. Installed aileron manual trim springs. Vacuumed under the seats. Wired pilot push-to-talk, installed stick grips. Test of the PTT's, showed I had a stuck mic..turned out I had a short to ground on the pilot stick(fixed).
Polished the side rail caps. I stilll need to design and build interior panels.
