more wiring. got the 90* antenna fitting and installed it int the radio tray. Routed wires and started anchoring them.
Located and installed the Dynon to PC connection 9 pin serial ports. Placed them in the sub panel, still need labels for them. This will allow connection either over the top when TIp-up is open or I can route a PC cable under the panel to the Pax seat if needed in flight. I will also use the EFIS 9 pin as a connection port for the GPS input from Avmap tp D180 during nomal ops. This connection needs to be broke when doing Dynon software updates, so this will work out perfectly, no separate switch needed,
Had 1 large wrap of spares/unused wires from Dynon harness, didn't want to chop them off(yet), so looped them in a bundle. Still have a lot of wires to connect, but should be the last time.
