Brian's RV-7 Web Site
RV-7
engine prep
Had to enlarge holes in the govenor bracket, then install it on the PCU 5000 governor. also had to rotate the arm to hopefully have it clocked correctly. re-lockwired 6 screws
Installed oil cooler supply/return fittings and oil pressure fitting
Installed fuel pump overflow and outlet fittings
rv-7 Home
RV-7 Home
672
firewall forward
45
107
264
milestones
Phase 1
visitors
