Brian's RV-7 Web Site
Date:  9-12-2009
Number of Hours:  1.50
Brief Description:  tail
Made some cuts on the VS fairing. Then started glassing it up.
Also making a glass skirt for the underside of the HS. 2 layers so far, will pull tomorrow and trim it up before adding another layer or 2.
Drilled the tips to the VS and HS. The VS tip is leaning and will need work.
