Brief Description: positioned wings for initial mating
Mike S dropped by to help me position the wings for initial mating. After he left I layed out the fairing attachment holes. Some key numbers:
1. wing tip is approximately 6.125" higher than fuselage bottom 2. wing inboard needs to be ~.375" higher than fuse bottom 3. minimum distance needed to mate wings is 24'. Prior to spars inserted into fuse, my wing tip to wing tip is ~23'. 4. RV-7 fuse length motor mount to tailwheel is ~18'.
