checked the comm antenna. All clear, no grounds, resistance check good. hoping my transmit problem is just due to antenna location and handheld. will do more checking once airborne.
worked on installing screws on tunnel sheetmetal and forward spar area panels. need to notch the pilotside more due to the trim cable interference.
