Finsihed up the gear legs and wheel pants. The installed the wing root fairings. Moved to the interior and wired the strobe power supply. checked flap rod bolts. installed seatbelts after fabbing inserts for oversized attachment holes.
Installed the air inlet/plenum boots. installed upper cowl, went much better this time. Thanks to Neil reaming out the hinges a bit.
