Started at 0630 warming up the shop and final wipedown of the fuselage. shortly after 0800, it started turning yellow. after 3 coats of yellow base and some cure time, I layed the first of many stripe lines. The striping layout took 5hrs. didn't take too long to mask off for the Purple base, then remasked for big bad green. finally around 1900 or so we were able to shoot some clear coat.
