Brief Description: gearleg fairing alignment and intersection fairing
aligned wheelpants to each other and fuselage. Drilled both wheelpants, then aligned gearleg fairings(pic 1). Next step is to modify the Vans lower intersection fairings. Left side fit ok, right side was bad. I changed mounting from Vans method and split them to be bonded to each half of the pants. should work out ok, will finish them tomorrow.
Spoke with the Paint shop. they will have booth time available next week, so I need to finish up some loose ends and hual the fuselage to them tomorrow. they will clean up my fiberglass work and other paint prep.
