Did as much riveting as I could by myself on the forward skin. Will need a rivet partner for the rest. Also riveted the side skins near sub panel. While doing the sde skins I realized I had not installed the cap strips on the center spar section.....pax side was easy enough to do now, but the pilot side required me to pull and reinstall the leftside throttle quadrant. that only added an hour to the build!
