I cut the lengths of the stick with e a tube cutter. I wired, soldered all the wires on the pilt and co pilot stick grip. I decided to go for the Ray Allen grips. A multi function grip on the pilot's side and a push to talk only on the co pilot side. The pilot has fuctions for Trim up, trim down, push to talk and autopilot disconnect. The wires were routed through the stick and I used water proof connectors for the pilot side wiring and a Molex for the co pilot as it will reside inside the stick.
