Brief Description: Throttle control subpanel decals
The throttle subpabel has been painted and the decals attached. Before the decals are attached they need to be "primed" with clear coat, in order not to smear when dipped in water. After clear coating and dipped the decals and attached to the subpanel. They will now dry for a day or so and then I will coat the whole sub panel with a semi gloss polyurethane clear coat.
