I selected the area inside the center of the horizontal stab for the ELT. I drilled the holes and installed the tray with steel pop rivets. I then routed the harness trough the fuselage all the way up to the instrument panel and attached the harness to the ELT remote. Next step is to install the antenna in the back.
