Brief Description: Added all the pitot, static and AOA lines
Installed the pitot and AOA lines in the left wing. I will install the heated pitot tube soon. Added lines in the fuselage. The pitot, static and AOA lines will be mated with the Dynon ADHARS unit which will be installed in the upper fuselage behind the baggage area. The backup instruments and T'd into the primary lines and installed to go to the fwd fuselage inbehind the instrument panel. The connectors will be added soon. I think I need to purchase the ADAHRS unit and get that one installed to complete the rear fuselage installation.
