Brief Description: Rudder pedal installation and tubing
Completed steps 8-9 page 28iS/U-03
Step 8: Removed the lower halves of the F-1235A & B Rudder Pedal Blocks and slid the whole Rudder Pedal Assembly into position in the fuselage as shown in Figure 4. Step 9: Secured the Rudder Pedal Assembly to the F-01201B-1 Firewall Shelf and the three F-01257-1 Rudder Pedal Support Channels using the hardware called out in Figure 4. (performed step 1 below prior to installation of the assembly)
Completed step 1- 2 page 28iS/U-04
Step 1: Threaded the brass elbows, called out in Figure 1, into the ports of the master cylinders as shown (used a small amount of Permatex pipe thread sealant on the threads). Clocked the elbows in the lower ports to direct their corresponding brake lines between the elbows in the upper ports. The elbows in the upper ports were directed upward. Step 2: Assembled the F-1289B-L & -R Cross-Over Brake Lines and connected them to their corresponding elbows as shown in Figure 1.
Completed step 1 page 28iS/U-06
Step 1: Secured the F-1289A-L & -R Reservoir Brake Lines to the upper elbow of both right side master cylinders as shown in Figure 1.
