Brief Description: Rudder and Brake Pedal Assembly
Completed steps 1-6 page 28iS/U-03 Step 1: There are 1/8 inch holes in both sides of the WD-1209 Brake Pedals. Match-Drilled #30 the hole in one side of both brake pedals into the underlying WD-1211-L & -R Brake Pedal Torque Tubes. Clecoed, then match-drilled the hole in the other side. Step 2: Drilled #12 all the way through the holes in both sides of the WD-1209 Brake Pedals and WD-1211-L & -R Brake Pedal Torque Tubes, then final-drilled 1/4 all the way through. Step 3: Removed the WD-1209 Brake Pedals and WD-1211-L & -R Brake Pedal Torque Tubes. Marked the parts to be reinstalled in the same locations. Step 4: Repeated the same process for match-drilling and final-drilling the WD-1209 Brake Pedals and WD-1211-L & -R Brake Pedal Torque Tubes for the other end of the WD-01206-1 Rudder Pedals. The parts were assembled as shown in Figure 2. Step 5: Removed and greased the WD-1211-L & -R Brake Pedal Torque Tubes then slide them into the WD-01206-1 Rudder Pedals. Step 6: Secured the WD-1209 Brake Pedals and F-1290 Pedal Blocks to the WD-1211 Brake Pedal Torque Tubes using the hardware called out in Figure 3.
