Painted the F-1205-L longeron that had previously been primed. Completed step 2 page 28-05 - Safety wired the four screws holding the gascolator bowl to the top of the gascolator. Completed step 3 - Installed the GAS-5 Gascolator to the F-1201C Firewall Bottom using the hardware called out in Figure 1. Installed the straight nipple to pipe fluid fitting into the gascolator from the aft side of the firewall bottom (used a small amount of pipe thread sealant). Fabricated the F-1259C Fuel Line Floscan - Fwall by unrolling and cutting off 8 3/4 inches of ATO-035X3/8 tube. Started at the Gas-5 Gascolator end of the tube. Inserted a nut and sleeve over the end of the tube and then flared the end of the tube. Made the two bends aft of the gascolator using the template given in Figure 2. Inserted a nut and sleeve over the flo-scan end of the tube and then flared the end of the tube. Attached the completed fuel line to the gascolator and the FLO-SCAN or FT-60 Fuel Flow Meter. Minor adjustment needed prior to final installation.
