Brief Description: Bulkhead Side Channels and Fuel Shutoff Valve
Completed step 3 page 23-04 - Riveted the F-1203G-L & -R Bulkhead Side Channels to the F-1203A Bulkhead per Figure 2 w/LP4-5 rivets in 8 places each side. Installed LP4-3 rivets in the two bottom holes on each side. Completed step 3 page 28-02 - Drilled #30 the FUEL VALVE 4161089 handle per the dimensions given in Figure 2. Completed step 4 - Installed the VA-104-3 Red Knob to the F-1259G Fuel Valve Bracket Handle per the instructions supplied with the knob. Completed step 5 - Installed the other end of the F-1259G Fuel Valve Bracket Handle to the FUEL VALVE 4161089 handle as shown in Figure 3. Installed the fluid fitting shown in Figure 3 to the FUEL VALVE 4161089 (using a small amount of Permatex #2). Completed step 6 -Installed the fluid fitting through the F-1259A Fuel Valve Bracket and into the FUEL VALVE 4161089 as shown in Figure 4 (using a small amount of Permatex #2). Completed step 7 -Riveted the F-1259B Fuel Valve Clip per the call-outs in Figure 4. Completed step 8 - Riveted the F-1259A Fuel Valve Bracket to the F-1276 Bottom Skin per the call-outs in Figure 5.
